PSU Issue ?
20 Oct 2011
I have a strange issue with my PC which I think may be the PSU ?
When I press the power button the pc will start to power up but 2 seconds later will switch off only to restart 2 seconds later and boot up ?
Anyone got any ideas ?
Thanks in advance
Craig
PSU is a Thermaltake ToughPower 1500W
What is your motherboard?
I get this with my ASUS V Gene when I've powered the PSU off then back on. It may be intended and changeable through the BIOS.
Yep my Gigabyte boards have done this in the past - are you overclocked?
Also check to see if your running the latest BIOS.
My old gigabyte board used to do this, i was always told you could disable it but never found out how. Its a bit like the long delay some current ones have as a boot test of some sort
actually, just realised you have the same board as me, mine has never done this but it does have a fair delay before it starts to boot. have you tried resetting the cmos?
