PSU Issue.
14 Apr 2011
Newark
I seem to be having an issue with my Leadex Platinum 1000w.
I am getting a warning notification when gaming says my 3.3v rail is only outputting 2.9v. I left HWMontior running to check this out and see if the notification would appear again and it did. HWMonitor show max just over 3.104v and the min at 2.928.
This is powering a 3970x and a Sapphire 295x2.
It's still under warranty, so an RMA, if required, is not out of the question.
I wouldn't trust a software reading mate, best you can do is use a multimeter to find out the real reading.
How much warranty is remaining?
Well if there's no issue with performance I don't see why you should RMA.
I've always had low readings as well, like I said they're not accurate.
