Hey guys,
I'm checking out some workstations at work, and the symptoms are as follows (there's no HDD in any of them):
1) Press Power ON - computer powers on for a time period of 1-8 seconds, then dies again
2) Repeated Power ON presses have no effect
If I remove the power cable, then SOMETIMES Power On has the effect described above.
PSU is a QTEC Gold 550W.
Pretty likely that its the PSU, no?
I would say that it only works after you remove the power cable because the thermal reset resets itself then
That's what you get with QTEC though
