Specs: i5 2500k @ 4.4GHz + ASUS 560Ti 448 + xfx core 550W PSU
I was trying to OC my card to its limit. I believe it is rated at about 200+W load. I increased the voltage to 1.075V from 1.0V and pushed it to 853/210 (core/memory) it passed 3Dmarks 11 with about P6250 scores. When I tried to push it a bit more 863/2100, it would not finish 3Dmarks 11 (it rebooted). If I keep voltage to 1V and set the same clock it would not reboot, rather it caused "driver stopped working" error and returned to desktop screen. I know every card can be different, but I have seen reviews with higher clocks. I suspect the reboot might be caused by insufficient power? On the packaging of the card it says 550W is the minimum. Which do you guys think is the bottleneck?
