- 3 Oct 2006
hey, planning on getting the V2000+ for my new comp, so the problem is its massive (which in itself isnt a problem) but i need some recommendations of a PSU with leads long enough to reach and do a little bit of cable routing.
if anyone has some suggestions based on own experience then that would be ace
thanks in advance.
edit: needs to be around the 600w mark (have considered the corsair but am not to sure if cables are long enough
thanks in advance.
