Would a corsair hx1000 cut it ?
Also, the Rampage II places the 1st 2 gpu's right beside each other with not even a mm to spare. Could this cause potential throttling with a pair of 5970's ? I know at the moment with 2x5870's, my 2nd 5870 runs 10 degrees cooler as a result of the gpu placing, and putting a gpu in the 3rd pci-e slot is not an option as it's on the edge of the motherboard and you need an 8th pci slot on your case to accomodate a dual cooler.
