PSU on way out? If so which one to replace it with?
15 May 2006
My PSU has done well to be fair and is 8 years old (Be Quiet P9 850w Gold, Modular)
Its done it for a while, months in fact so I'm a little reserved to just whip it out and change whilst it in theory works
The problem been its making a very very slight crackling noise, (nothing that scares me, possibly that resembles some phone charges when the phone battery is full) if fact I couldn't say if this was a natural side effect as never placed my ear to any other PSU!
But maybe a capacitor is going/gone duff (wild guess I know nothing about circuitry!)
Every 10 seconds the fan ever so slightly slows and speeds back up and it can only be described as hard disk clicking (lasts about half a second) at the same time the graphics card fan also fluctuates, so I'm guessing the power distribution is also been affected.
I'm all set for it been a gonner to be honest
My Rig consists of for power mainly gaming on
i7 6700k (fractionally overclocked)
Zotac 1080 amp extreme
Couple of SSD and a mechanical drive for the main of data
In future will likely change the graphics card to meet game requirments
Any advise is much appreciated as always
Any of these would be a good replacement - I'd pick the Seasonic, cheaper with longest warranty.
My basket at Overclockers UK:
Total: £296.03 (includes shipping: £11.10)
Quite fancy the
https://www.overclockers.co.uk/evga...-platinum-modular-power-supply-ca-029-ea.html
This worth the extra few quid?
Higher than 650w only for futureproofing/overclocking - the rated wattage actually drops slightly per year as the capacitors age, and the efficiency of the PSU drops under lower load.
Is there any major advantage to the prime range?
Or focus best option?
Prime is basically luxury model serie with more heavily oversized parts.
For example "up to twelve and half" level primary capacitance big enough for over 30ms hold up time when ATX spec requires 16ms.
Efficiency wise only 80+ Titanium models has something over Focus Plus.
That's actually first efficiency class with any requirement for below 20% loads.
Seasonic who has also many times in the past paid attention to low load efficiency took also that to crazy level.
Exceeding 80% efficiency at 3% load and 90% efficiency at 10% load rating with lowly 115VAC which gives little lower efficiency number than European voltages:
http://www.tomshardware.com/reviews/seasonic-prime-titanium-650w-psu,4690-5.html
@Blackhorse
focus plat version on sale. damn good warranty and build quality
also, since you liked bequiet, there new modular and wire-free model is out- but you do pay the price for a £20 silent wing fan and internal wire free design. compared to your older model- bequiet switched to FSP to make the units .
Total: £217.00 (includes shipping: £11.10)
@Blackhorse
Thanks for your help
I've ordered the
https://www.overclockers.co.uk/seas...plus-gold-modular-power-supply-ca-068-ss.html
Hoping I made it in time for delivery tomorrow
Been at work all day and first chance I've had
Was nervous on the 550w whether that would cope in 5 years time
Also reviews I've read say the only negative thing about the focus range is the slightly smaller fan can cause it to spin faster and louder to keep up to the slightly larger counterparts on the prime model
Thanks everyone for their help
