Hello all..
Got an irritating problem you might be able to help me out with..
I have a computer running with a Corsair 620W psu, Asus P5K motherboard and some other stuff..
It has been running well for the last year or so, but today I got a problem. The computer was on standby, so I woke it up as normal.. It did not wake, but tried to restart a couple of times (or at least that was what it sounded like) - there was never any signal to the monitor.
Oh well I closed down the PC by holding down the power button for a few secs. Tried to restart the computer but nothing happend AT ALL.. No spinning discs or fans no light on the cabinet buttons - 99% dead (mobo LED was on).
Tried to take out all cables and re-insert those - no luck. Tried to disconnect as many items as possible - nada. One ram module etc - nothing helped.
I first thought it was my Corsair 620, so for the fun of it I tried another PSU. This one only had a 20 pin connector, but I reckon if it was the PSU the other one would perhaps be able to give some sort of sign - but nothing happend.
Unplugged the Corsair and bridged the green+black wire and turned it on without the 24 plug in the mobo. Drives, fans and so on turned on... So that kind of indicates the PSU is still ok - right?
I got an idea that it just might be the contact on the cabinet, so I shorted the right pins on the small irritating wires on the mobo - but that didn't do anything.
I have no other things to test with, so I probably need to start purchasing until I fix the problem
Does it sound like a dead mobo?
Thanks in advance.
Thanks in advance.
