PSU or MOBO fault?
7 May 2015
Hi,
I’m trying to diagnose a fault that has occurred on my system, short history, bought it second hand have stripped it back to individual components cleaned inspected and rebuilt. System worked perfectly after rebuild and loading a fresh install of win 8.1. had one issue it wouldn’t connect to the LAN, MOBO has the Bigfoot killer e2100 chip onboard, ended up plugging in a TP-link wireless board and everything seemed to be working fine.
Next day tried to start system and it just seems to be in a continuous on off loop at Post.Have removed everything from the MOBO apart from the CPU and Cooler, tried to boot and it’s still doing the same thing just looping starts looks as if it’s trying to post then shuts down, starts tries to post etc. The only thing I haven’t got is a case speaker so am not able to hear any diagnostic code from the MOBO. Any ideas from past experience would be much appreciated.
System spec is,
Intel 2nd Gen i7 sandybridge 2600k 3.5Ghz
Gigabyte z68 G2 sniper
Gpu: 4gb Msi R9 290 Pro
16gb (2x8gb) Avexir core ram 2133mhz
Psu: 700w coolermaster silent pro
SSD: Crucial MX100 250gb
HHD: Samsung F1 1TB
Cpu cooling: Corsair H100 fitted with Silverstone SST-FQ121 FQ Series 1225 PWM Fans
Gpu Cooling: Corsair H50 with nzxt g10
Have you got 1 stick of RAM in? The machine won't POST or reach BIOS unless it can detect memory.
You can also try clearing the CMOS memory and see if that has any effect.
One of the first things it does in POST is check for extended RAM after the jump command! This would not cause a reset! :p
Could be a few things, PSU, CPU overheating. Dust in connections, or the motherboard itself.
I would bet on the PSU, however.
Fair point. I've never tried booting without RAM installed before so I assumed it would cause a reset.
Wouldn't a CPU overheat just cause a thermal shutdown rather than a reset?
would my spare 500w PSU with just the one 4 pin ATX connection be enough to power the basic system and boot it with ram inserted?
It should be OK if it's just the CPU, RAM and CPU cooler. If it POSTs successfully, then you should be able to isolate the PSU as the problem.
Should be OK to test, this supplies 12V to the CPU Vreg's, it might not work if the motherboard expects 2 12V connection however.
I'd give it a bash to help rule out the problem.
Ok have swapped out power supplies fault still exactly the same. have also connected a case speaker which is giving constant short beep. Looks as if we are getting closer to the fault. I have also fitted the 700w power supply into the old PC and it's running perfectly.
Do you get any audible beeps with no RAM (3 beeps of 3) to indicate the lack of extended memory.
Be careful if you are looking at the CPU (PGA - Pin Grid Array socket) the pins are easy damaged. A wee check of the pads on the back of the CPU for dirt etc. sometimes even just re-installing the CPU, the PGA pins will re-cut into the back on the CPU can give you a better connection.
Try the VGA card in a different slot, also try cleaning out the RAM slots and gold fingers on the DIMMs - Good luck
Could be shorting out data bus lines, some ArctiClean may shift it, or "Ethanol" Isopropyl Alcohol (propan-2-ol) or IMS (Methylated Spirits) will do the job. A very sharp scalpel blade may help to also loosen it.
have cleaned the Tim off and replaced the mobo everything seems to fine... thanks for all the help I'm quite pleased actually my first full strip and build and am learning all the time. ... I'm going to start another post on the memory section of the forum I'm having a problem with the XMP profile for the ram.
