I am a newbie to this site and just like to introduce myself: I have been a software engineer for many years, now retired for some 5 years. My last build was a dual P2 processor which I currently run. I thought it was time to build a new system and have gathered all the components apart from the memory.
Lian PC-P80B
Revelution85+ 1250w
Asus R3E
I7 980x
Megahalem,
Sapphire 5970 toxic 4GB
Crucial 256MB 300 SSD 6Gb/s, WD 1TB Caviar black, 6Gb/s (64MB Cache),WDRE4-GP 2TB SATA-II (64MB Cache).
Pioneer BDR205
Memory: Corsair 12GB - CMG6GX3A2000C8
NZXT Sentry 2 Touch Screen Fan Controller.
Since my new system is along the same lines as the OCuk’s supper gaming platform only higher specs, I thought you guys would be able to help: My problem is the orientation of the PSU, should I have the fan above or below. The P80 case has an extractor fan on top and therefore draws air out in that direction. If I have the fan on top, it will disrupt the airflow out of the top of the case while drawing air in from the rear top vent. The PSU shelf of the P80 has holes and if the PSU is fitted with the fan down although some intake is obscured it will take in the flow from the CPU cooler (Megahalem). Looking at the PSU from the rear in this orientation (fan down) the switch is below the socket, leading me to suspect that the correct orientation is fan up, i.e. power switch above the socket, any ideas?
Lian PC-P80B
Revelution85+ 1250w
Asus R3E
I7 980x
Megahalem,
Pioneer BDR205
