Hi all,
I'm looking into replacing my power supply.
System specs
i5 2500k @ 4.2ghz
Corsair H60
Corsair 16GB 1600MHz DDR3
2 HDDs @7200RPM
1 80gb SSD
Sapphire Radeon HD 6950
Corsair TX 650W ATX SLi PSU
Using this Thermaltake Calculator, it says I need 733W. I imagine this is overdoing it slightly, as the 650 I have at the moment is 5 years old and hasn't blown up yet, but still.
Do you have any recommendations or a clear idea of how much power I need? I'm having trouble sorting through the endless list and would rather not just pick an 80+ rated one at random. Only requirement is for it to be modular. I imagine it probably needs to be 750W+.
While we're at it, if I were to upgrade any other part of my system in the near future, what would you recommend starting with? Where's the potential botteneck?
Cheers!
System specs
i5 2500k @ 4.2ghz
Corsair H60
2 HDDs @7200RPM
1 80gb SSD
Cheers!
, you will get a more accurate reading.
How is it semi modular? Can't see it being an issue - All I want to do is get rid of two of the excess cables I currently have in there without having to bury them under the hard drives.
