PSU Power and Corsair commander issue
12 Feb 2021
Hi all
I have some issue with my fans in the last the days using the Corsair Commander Pro... They aren`t go more then 600 RPM. Whatever the profile will be just stuck on 600 RPM. Anyone knows about this issue ? And aslo are flickering when switching from a game to desktop. Fans are UpHere t3syc3-6
And the other thing .. I`m not pretty sure my 80+ Gold RM650 Corsair it`s enoung for my build. I just think .. i`m new to all of this things. Any helps and tips regarding that ?
My build:
Ryzen 5 2600x with Be Quiet! Dark Rock 4
2x8GB DDR4 Corsaird Ven
MSI RTX 2070 S
8 RGB FANS
1 SSD
MANY THANKS FOR ALL OF REPLYs
I kept having ports die on my commander pro because they (the fans) would randomly stop showing up in iCue. Admittedly I was running 3 fans off one header BUT the total power draw was well within the 1A per header so....
Swapping the fans to another port would get them going again for a few months but eventually the same would happen. I put it down to some funky power spikes killing the header.
Had to get a 2nd commander to power the rest of the fans and run the case fan off the motherboard itself, just to be sure.
Have you upgraded the firmware of the commander? Tip: export your profiles before you do, unless you fancy setting it up again :p
Hi guys thanks for replys .. I think it today to run only one power cable just for commander to see if that will chance anything.. Funny it worked and get back control for 4 fans out of 5 :)) and one haven`t even switch it off so i changed that one to the only empty port left on hub .. And now everything works perfect. I think this hub is just rubbish on that fan ports. Will see what will be in the future.. One more thing guys .. I`ve added one more fan to the Dark Rock 4 for exhaust .. Will not get it melt or anything like that , right ?
