PSU power lead too short. Help needed!
30 Nov 2006
Arrrrgh, this build is a nightmare!
Right, so I'm using a Tagan 530W PSU (TG530-U22), in an Antec P180 case, with a BFG 680i mobo, with a tuniq tower cooler for an E6600.
Simply put, the 8pin ATX connector in the top left hand corner is a tiny (1-2 cm at most) bit too far for the power leads to reach, if I have the CPU cooler fitted. Now without the CPU fan, it will fit, but at a stretch, and obviously, no cooler = no go.
So, I come to you folks for any possible solutions. I'd really like to avoid buying a new PSU, but if anyone is using the same rig (P180, BFG 680i, Tuniq Tower), if they could post what PSU they have, that'd be a good start.
I was thinking maybe its possible to get a sort of extension, that I could connect to the power leads, and then connect to the connector on the mobo and have say, 1-2 cm of cable between each connector so that the cable could reach, but I have no idea if such a feat is possible.
Any other suggestions greatly welcomed.
Tom
So I did some online snooping, and i've found you can get 4 pin extension cables no problem, but 8 pins are a few and far between.
I'm going to call a local computer shop tomorrow morning, and see what they say. I'll update if and when I find a solution.
Also, any PSU recommendations would be great, as I will need to upgrade PSU in a month or two when I go SLI.
Search in google "8 pin atx cable" and use images to view the findings. Then click on a few and you should be able to get one that way.
Well after a fair amount of searching and ringing round, I've had absolutely no luck finding an 8 pin extension cable. 4 pin I can find absolutely fine, but 8 pins just don't seem to exist any more.
Now the question I have is this: If I use a 4pin extension cable on this motherboard, so i only a 4 pin connection on it, will it have any negative affects on it? I've heard it can melt the plastic casing and that sort of thing, so obviously I want to avoid doing this if at all possible, but if it gets my computer up and running, that'd be lovely.
If not, I guess its a new PSU. Will the corsair DEFINATELY reach? My tagans power cable is about 45cm long, so any longer than that would be good.
SkeeterPSA said:
Did you even try to google what i said to. Its dead easy to find a place to buy a 4pin to 8 pin adaptor that way.
4 to 8 pin adapter, not a problem, 8 pin EXTENSION, however, not so easy.
I've found a US company based on ebay who do sell them though, so I'm waiting to see how long their turn-around is. If it's more than a few days, I'll just buy a new PSU.
An E6600 doesn't require an 8 pin connection.
Due to the lower wattage requirements the 4 pin is fine.
As you are probably aware, the 2nd 4 pin connector on the motherboard quite often has a blanking plate fitted to it.
8 pin is required for the P4 9xxx dual core cpu's.
Wow, thats extremely good to know! If thats the case, I should worry about it then, should I?
The reason I've been seeking the 8pin extension is simply because the mobo manual strongly recommends you use the 8 pin connection. Is there reason for this, if it's not actually necessary for my CPU?
I have exactly that setup, and a Seasonic PSU reaches (although it goes over my 8800 GTS rather than round).
http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-SS
