hi all,
i will keep the story short.
the system.
Phenom II 965 be
4gb ddr3 1333mhz
asus m4a88t-m
antec 902
wd hdd 500gb
liteon Odd
xfx core edition 650w psu 52a +12v single rail
Asus gtx460 1gb
Windows 7 64bit
17" monitor
I had many problems with the build and took a month to get working after 3 cpu's, 4 motherboards anf 4 sets of memory.
The problem is the psu is arcing after 1 week of using so i have had to send it back (Rma'd). i have now got another psu from a local shop, the problem with this psu is it is EZcool.
It had dual rails 20a on each and a total of 40A +12v rails. 650w total power and a cheap led loud fan.
Can i run my system with this psu, i am running it at the moment without the gtx460 but my onboard hd4250 is no good for anything apart from looking at the net.
I have posted on a few forums and they have game me a few answers but not a yes you can or dont run it with that shed of a psu. it is only going to be running for about 14 days max and if i have to i will still run the games on min settings, i just need the games to have a smooth frame rate and not look like a slide show.
Thanks
the system.
Phenom II 965 be
4gb ddr3 1333mhz
asus m4a88t-m
antec 902
wd hdd 500gb
liteon Odd
Asus gtx460 1gb
Windows 7 64bit
17" monitor
Thanks
. Maybe the odd light game every now and then, and less playing on minimum detail should be fine.
