- 11 Oct 2007
Hi all I’m after a bit of advise My old Jeantech 500W PSU went Bang the other night so I’m looking for a replacement.
Now PSU’s seem to have moved on a lot since I bought this one So I would like to know the following, will a new ATX12V v2.2 24pin PSU work with an old ATX v1 motherboard?
My motherboard is an ABIT IC7-G 478 socket with a Pentium 4 3.2 CPU which is ATX12 V1 board I believe and I’m thinking of purchasing a 520W Corsair HX Series Modular PSU.
I know that the 24pin can be split to 20pin and you also get the standard 4pin 12vATX connector but what has made me unsure is that the Corsair states “Supports the latest ATX12V v2.2 and EPS12V 2.91 standards and is backwards compatible with ATX12V 2.01 systems”
Please can someone advise if this PSU will work ok with my motherboard and if they would recommend this particular PSU or another?
Thank you in advance for your advice.
Longshot.
Longshot.
