PSU problem- faulty or not enough watts?
18 Sep 2016
Hello all,
I've successfully constructed my first rig, though I believe I have encountered problems with my power supply. Upon running FurMark for the first time my computer crashed and informed me that a power surge was detected. Having done some research, I believe that my PSU is either a) faulty or b) not sufficient enough to power the core components when under load. Based on the specs provided by Nvidia my GPU requires, at the very least, 600W- which my current psu provides. However, I assume my motherboard consumes at least twice as much, levels which my current psu theoretically won't be able to handle. If is the case what PSU is recommended? (no higher than £100). Of course, power consumption may not be an issue and I may simply have a faulty PSU. If this is the case will 650W be enough?
Specs listed below
Computer specs:
GPU: GeForce GTX 980 TI (http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-980-ti/specifications)
CPU: I7-4790k 4 GHz Quad-Core ** No Competitors **
Motherboard: ASUS Z97-Pro gamer ATX (https://www.asus.com/uk/Motherboards/Z97PRO/)
PSU: VS650 (http://www.corsair.com/en-gb/vs-seriestm-vs650-650-watt-power-supply)
Thanks for taking your time to read this
You'd expect even the lower end Corsair 650W PSU to be able to cope with that system. 50A something on the 12v rail. If you had two graphics cards then maybe it would be a different story.
Windows doesn't always diagnose crashes very well. Try other benchmarking programs and see if they fail.
