Hey guys.
Something weird is going on and I though maybe you could help.
Swapped my PC into a new case recently along with a new Ocz 600w PSU.
I also installed a new hard drive.
Since then, everything seems to be working except when I load WOW, Windows crashes. And I mean instant freeze, no BSOD or anything.
Have reinstalled Windows along with WOW and it has made no difference.
Am I right in assume that the PSU is the main suspect after this?
Strange thing is, I have run Prime95 and 3dmark to try and stress it and they both work fine.
Any suggestions?
One more thing. Is there any particular way round the GPU power cables from the PSU should go? What I mean is, one is 8 pin with a cut out to use with 6 pin cards and the other is 6 pin. My GTX260 needs both, but I was wondering if anyone had any ideas if one should go before the other?
Thanks.
Any suggestions?
Thanks.
