- 1 Apr 2010
- South Shields
Hello OcUK.
I have a Acer Aspire One AX3300 - sort of mini-media computer.
It first started ok last year when i first turned it on, and now for the past 2-3 weeks the power to the tower will randomly stop, and then the system shuts down, which is a pain since i have piles of college work to complete for the next couple of weeks.
First i thought it was the cable itself, so i pulled it out and it seems fine, then my attention turned to the fuse which in my case is a 10AMP fuse in the plug. Pulled it out and couldnt see anything wrong with it, put it back into the plug, made sure it was properly secured, plugged it into the socket, put the cable back into my tower, and the power turned on.
I then left it for around a few days, and totally forgot about it and then about 7 days after the initial power-down of the system (obviously i had manually shut it down overnight etc) it turned itself ofd again, so i used the same procedure and it worked again.
Now....in the past 24 hours, its shut itself down 3 times, one of them being only 10 minutes ago, and i was wondering is it a fault wih the actually fuse, because i haven't replaced it as of yet, but i will be replacing it tomorrow when i can get into town, or do you think it might be the actual psu in the system itself?
Any advice would be greatly appreciated, i need a reliable system for when i come to rendering just before christmas.
Cheers
Ash
EDIT:
Specs;
Win7 HP 64bit
4GB DDR3 RAM
2x 250gb HDD's
Blu-ray/Super-multi combo optical drive
nvidia geforece G210 512MB (mobility i presume as its not overally good)
AMD Phenom II x2 545 dual core CPU @ ~3.00Ghz
I think thats all :|
Cheers
Ash
EDIT:
Specs;
Win7 HP 64bit
4GB DDR3 RAM
2x 250gb HDD's
