7 Feb 2013 at 02:39 #1 rabc1690 rabc1690 Permabanned Joined 29 Jan 2013 Posts 317 What's best orientation to fit a psu in bottom of case. With the fan facing down sucking in air from the vent in the bottom or facing up
7 Feb 2013 at 02:56 #2 dacads dacads Soldato Joined 3 Sep 2012 Posts 11,588 Location P town Doesn't make much difference but better to have fan pulling in fresh air from bottom rather than warm air from the case
7 Feb 2013 at 02:56 #3 rabc1690 rabc1690 Permabanned OP Joined 29 Jan 2013 Posts 317 Kewl mate wasn't entirely sure if it really made any dif
7 Feb 2013 at 03:01 #4 troops troops Associate Joined 20 Jun 2009 Posts 1,178 Location Pieland Mines facing down, aslong as theres a nice bit of clearance under the case but tbh either way will do.
7 Feb 2013 at 03:55 #5 Cupra Cupra Permabanned Joined 12 Feb 2007 Posts 8,731 Location Teesside Whatever direction makes for better cable management.
7 Feb 2013 at 05:06 #6 rabc1690 rabc1690 Permabanned OP Joined 29 Jan 2013 Posts 317 That's what I was thinking about if upside down less cables lying about. Plus I have a vent plus dust filter on bottom as well
7 Feb 2013 at 05:47 #7 harshuk harshuk Associate Joined 20 Jan 2013 Posts 361 Location Ipswich rabc1690 said: That's what I was thinking about if upside down less cables lying about. Plus I have a vent plus dust filter on bottom as well Click to expand... Solved
7 Feb 2013 at 10:44 #8 Gibbo3771 Gibbo3771 Associate Joined 5 Sep 2010 Posts 774 Cupra said: Whatever direction makes for better cable management. Click to expand... Also whatever way the screws fit on the back
