Psu query
19 Sep 2018
Hi I’ve just upgraded and have put in a psu a freind gave me, problem is the hdd wasn’t found in the bios, I then notice the hdd wasn’t powering up so tried in a different pc and still nothing, i then took a hdd that worked from the other pc and connected to mine and same thing happened it wasn’t powering up then re connected it in the pc it had worked and it then didn’t power up
Can a psu do this?
Was using the pc like normal just without a hdd connected so I would assume I’ve had a lucky escape and the rest of pc is ok?!
Thermaltake dps g 750w everything else seemed to work and was playing games on it until I worked out the psu could be the problem.
Everything else seemed to be working apart from the hdd, putting a new psu in later and hdd, fingers crossed!
Put a new psu in and a new hdd and works fine hdd found straight away and not getting zapped! Thanks for the help.
