Im going to build myself a new Rig at the end of the month and i have had a look at power ratings for the graphics cards etc and i have chosen this http://www.overclockers.co.uk/showproduct.php?prodid=CA-048-CS The Corsair CX600.
Now im undecided on my GPU so far and i looked on AMD's site and saw the power specs for the HD7970, it is a 500w minimum (same for the GTX670) i then went on to click the link to check the certified PSU's and the Corsair CX600 wasn't on the list.
its gotten me worried that the PSU is maybe not upto the task of what i want it for i want it to power my new rig which will include:
I5 3570k
Gigabyte Z77 ATX mobo
8GB RAM
1TB HD
1 optical drive
and a GTX670 or HD7970 i have not decided which gpu i want yet.
Also it has to power as many fans as i can fit into the Corsair carbide 300 with a Fan controller and i already have an arctic cpu cooler
Will the Corsair CX600 power this? im looking to overclock the CPU sometime in the future to around the 4GHz mark. I have a Xigmatek 500w PSU in my current 955 rig with an HD 5850 but i dont want to risk my new system using that. thanks for any help.
I5 3570k
8GB RAM
1TB HD
1 optical drive
