PSU question- powerful enough for 5870+physx card?
27 Apr 2009
Hi chaps,
this is a PSU question so there's no specific place,
can you help...
I've got a 5870 on an antec trupower new 650w, specs in my sig
I just got hold of a GTS 250 and I'm about to try and run it alongside my 5870 as a dedicated physx card, found an excellent hack that's stable as far as I know from reviews etc.
I'm running CPU 3.4ghz but I'm hoping to OC it to about 3.7... phenom2 quad 965 black edition,
Will everything run hunky dory do you reckon? With 650w PSU? I'm not upgrading my PSU as it's only about two months old as it is, you reckon it can handle a bit of OCing plus the GTS 250? Are they power hungry running in PhysX config?
will keep you posted on that. they definitely are still implementing the block...
you need to backdate the drivers and there is a new way that avoids hacking a dvi-vga splitter with resistors :P
