PSU Question
17 Dec 2004
Crawley, WEST SUSSEX
I currently have an OCZ Modstream 520w. And on everest and other detection software it says the 12v is at 11.71 which i thought was a bit low is it? I am also going to be getting a watercooling setup in July and basically worried its going to stress the PSU even more. I will also not have enough Molex connectors as there are only 4 i think on my OCZ (I need at least 6/7), I would also like to have an extra pci-e connector if I want to go xfire later on.
Taking all this into account I have been looking at the Enermax Liberty PSUs. Just wondering what one to choose the 400w, 500w or the 620w? Thinking the 620 one if I am eventually going to go Xfire. Or do I stick with the OCZ one get some molex splitters and wait for the Seasonic M12s to come out in September?
yeah go for the 600w if you wanting to go crossfire/sli in the future. you wouldnt want to get a new psu and then later down the line find out that you need another one because its not powerful enough. looking at your specs, the 600w will do good.
i have OCZ modstream 520 watt, and its the best PSU i have ever bought, i have had my PC running with two 7800GTs in SLI (friend wanted to see if his cards were boned) and it didn't miss a beat, just bought my second 7600GT and wacked it in, flicked on button and voila, no problems
How in hell did u get a second gfx connector then? And unfortunetly all the connectors on the PSU are being used as it is so will definietly need more molex's if i am to go Watercooling.
SLI PSU's have two graphics card power output connectors (ie on the Enermax Liberty the 2 red connectors + cables are for the graphics card)
