snarloas1982 said:newer technology, support for new motherboards
Between ATX 1.3 and 2.x yes but ATX 2.0 and ATX 2.x there isn't much.newer technology, support for new motherboards
ATX 2.x is backwards compatible and usually includes adapter for the main 24 pin ATX to the old 20 pin standard (or the extra 4 pins for newer boards detaches).Both are the same thing though? 2.2 would work with an older atx motherboard?
Tetras said:20 pin ATX connector, ATX 1.x.
Post #4 m8Tetras said:ATX 2.x is backwards compatible and usually includes adapter for the main 24 pin ATX to the old 20 pin standard (or the extra 4 pins for newer boards detaches).
