PSU question
3 Jan 2006
hello..
I have a Tagen TG480-U01 and I plan to swap the following
Gigabyte GA-8I915P Duo Pro
2x512 DDR
Pentium4 3.0Ghz
for...
OCZ 2GB PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz
Gigabyte GA_965P_S3
my gfx card is a Sapphire Radion X1950XT
does anyone know will the Tagen still be able to power it? it has no problem at the moment.. and I was thinking that the Conroe used less power.. but then I know nothing. :)
just I don't want to get it all, stick it all together only to find i then need to wait a few more days as I have to order a new PSU.. that would just depress me... lots..
anyone have any ideas on the matter..?
thanx.
You would be cutting it pretty close especially with the 1950, but it should just about work I think because Tagen is a quality brand.
