sorry if this has been asked before, but I have looked around and not quite getting the answer
I am about to buy a gtx 480 from a friend.
I looked at a few power usage calulators, and in a nut shell, they all seem to agrea i need a 650 psu (i will go for at least 750 to be safe)
the problem i am having is... I have read somewhere that the 580 needs 42a on the rails.
there dont seem to be that many psu's with that much ampage on a single rail
so, my question is.. considering that this card requires 2 8 pin conectors.
if i get a psu with lets say 30a per rail, and then use 2 seperate cables for the 2 8 pin conectors, will that achieve the purpose.
also how do you tell if a cable is on a the same rail as another.
is there some kind of understanding psu's for dummies link?
i have seen some psu's with '1 rail for efficient power distribution' offering 60ish amp on the rail, is tha the way to go?
in a summary......help !!!!!
