PSU recommendation
28 Mar 2012
Looking for a PSU for The following setup: A 2.4 ghz Core 2 duo, 260 GTX, DVD-RW and a HDD. It won't be overclocked or have anything else added to it. There seems to be a huge price range for similarly rated PSUs on the OcUK site. I don't want to spend too much, ideally less than £80. However if paying a little more makes for a big jump in quality I would consider it.
Corsair do a range of PSU's in all diffrent price ranges and they are excellent PSU's.
Check them out
http://www.overclockers.co.uk/search_results.php?sortby=&groupid=701&search=Corsair+PSU
Alternativley OCZ do quite cheap decent power supplys so maybe they are worth checking out too but out of the two i would go corsair (i own an AX750)
They are the only two brands of PSU i have tried but im sure there are more just check some of those out
I have got several OCZ PSUs and they have all been high quality and have lasted for years. I recommend them because of there excellent value and high performance.
Thanks for the suggestions, those are less money than I planned for which is good. I will probably go up a bit on wattage to be on the safe side.
