Hi
In need of a psu for a rackmount case, the one that was in the pc that's been transplanted into the case has leads which are too short, probably could do extensions but if I can get a cheapish psu might be better, cant have a bottom mounted fan which is the main problem so a front and or rear mounted fan only, needs at least 5 sata and 1 molex
Cheers
Cheers
