Psu recommendations quiet running
6 Aug 2009
Hi I have an HP Envy 860-007na and the PSU needs replacing. It’s got this currently;
Picolit 500w Estarbronze. Up to 50 budget.
mist be quiet running. 500-600w
thanks
That case uses PSU as case exhaust, so its fan needs to be running good amount andthat's position where cheap PSUs don't last heavier use.
Especially if there's higher end graphics card without radial fan cooler to exhaust its heat directly out from the case.
