psu recommendations to power a r9 280x
8 Aug 2013
Stoke-On-Trent
Planning on getting a gigabyte windforce rev.2.0 r9 280x and need a new psu as mine is only a 500w corsair builder series. Any recomendations?? Been looking at a few be-quite ones. Are they any good or should i avoid be-quite?
8320 fx
Gigabyte 970a ud3 rev 3.0
1x500gb hdd
1x120gb ssd
4x 12cm fans
Im probably missing something its abit early lol
Then yer Superflower should do fine for you if your budget is tight.
If you have more budget and would like to have a higher end brand have a look at Seasonic Fanless series :)
Superflower are a higher end brand, they are just not as well known as Seasonic.
