psu, seasonic?
Permabanned
29 Oct 2006
ok i need a decently powerful psu around 500w probably, as i am intending to upgrade to core 2 duo soon but i want a repliable and safe one that will protect my mobo, cpu, etc. if there was to be a power surge, i want a quiet psu. now to the main question....what should i go for? i have heard seasonic are the quietest and are a very good make, also heard enermax are reliable and corsair are quiet, opinions please.
cheers
nick
Corsair PSUs are currently based pretty much on the Seasonic M12 design but they are a little cheaper. You can't really go wrong with any of the PSUs you have mentioned so I'd probably suggest going with the cheapest of the selection.
I'd recommend you buy a surge protection strip or similar though as that would protect the PC(and PSU) better than just relying on a fairly expensive PSU to sacrifice itself.
I went through 2 Enermax Liberty 620w's (both just stopped powering up) then I ordered a Seasonic M12 and couldn't be happier.
I bet you could if it made coffee also, I too have a Seasonic 500W, best PSU i've ever used, but buying now I would get the M12 series because of the braided cables.
Simon_D said:
http://www.overclockers.co.uk/acata...r_Supplies.html
Seasonic M12 Modular 500W Silent ATX2.0 Power Supply (CA-005-SS) Price: £79.99 (£93.99 Including VAT at 17.5%)
Seasonic S12 500W Silent ATX2.0 Power Supply (CA-001-SS) Price: £67.99 (£79.89 Including VAT at 17.5%)
£14 extra to have detachable modular cables
__________________
DFI LanParty UT CFX3200-DR RD580 Bios R5UD728
AMD Athlon 64 X2 4400+, 4 x 1GB PC-4000 Crucial Ballistix
Powercolor Radeon X800GT0 256mb, SoundBlaster X-FI Pro
Seasonic S12 600W
But it's all worth it!
