25 Dec 2011 at 19:23 #1 Daphatboy Daphatboy Associate Joined 21 Mar 2011 Posts 102 hi guys, what sized PSU do you think would be suitable for my setup (in my Sig) along with a corsair h60 and two fans in push/pull. and also, if a modular PSU worth it? cheers
25 Dec 2011 at 19:27 #2 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 19,226 Location West Side Cooler Master Silent Pro Modular http://www.overclockers.co.uk/showproduct.php?prodid=CA-166-CM&groupid=701&catid=123&subcat= and if you plan to add another 6950 XFX Pro 750W Core Edition '80 Plus Bronze' Power Supply XFX Pro 750W Core Edition '80 Plus Bronze' Power Supply http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-XF&groupid=701&catid=123&subcat=
26 Dec 2011 at 00:32 #3 Daphatboy Daphatboy Associate OP Joined 21 Mar 2011 Posts 102 so would a 650w PSU be suitable? I don't plan on going crossfire in a while. what are peoples thoughts on modular PSUs?
26 Dec 2011 at 00:34 #4 fowler002 fowler002 Soldato Joined 23 Oct 2008 Posts 5,044 is there an issue with your current psu?
26 Dec 2011 at 11:14 #5 Daphatboy Daphatboy Associate OP Joined 21 Mar 2011 Posts 102 Well I have had a few kernel-power related BSODs, and with getting a water cooler and another fan I thought I should probably get a new PSU
26 Dec 2011 at 20:00 #6 Daphatboy Daphatboy Associate OP Joined 21 Mar 2011 Posts 102 Is there any massive benifit to a modular psu? Would you say 650w is ok?
27 Dec 2011 at 00:13 #7 Daphatboy Daphatboy Associate OP Joined 21 Mar 2011 Posts 102 Choices: http://www.overclockers.co.uk/showproduct.php?prodid=CA-054-BQ&groupid=701&catid=123&subcat= http://www.overclockers.co.uk/showproduct.php?prodid=CA-166-CM&groupid=701&catid=123&subcat= http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-XF&groupid=701&catid=123&subcat= http://www.overclockers.co.uk/showproduct.php?prodid=CA-117-AN Ideas?
27 Dec 2011 at 00:15 #8 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Well I would probably go with the Antec of the XFX PSU from the list above.
