PSU struggling
10 Apr 2004
Weston-Super-Mare
Hello all
Think my PSU is struggling; fan seems to be fully on all the time a lot of heat coming out of it.
So looking for a change!!
Have a water pump, 10 fans, OC CPU etc see sig, also will be upgrading graphics card real soon GTX sli would be nice :)
What should I get???
Also going from 2 gig memory to 4 gigs is it worth going the whole hog and getting 8 gigs as memory is so cheap at the moment, this pc is only used for gaming…
Many thanks, Martin
Hey there. You've not really said if you would value having modular cables, so umm, I'll assume that's not a big deal for you. Models to check out would be the:
750w Silverstone Olympia
750w Etasis Gaming Power
750w PCP&C Silencer Quad-Pcie
If you were thinking of dabbling with modular you'd want to look at the:
750w Silverstone Decathlon (it's simply a modular Olympia)
720w Enermax Infiniti
Silverstone or Etasis mate. If your thinking of SLi with a quad core and all them bits I'd be looking at 850W perhaps? I've got the Etasis ET850, cracking bit of kit.
PS what's your job? :D
