Which version of the CX500 do you have. There have been four revisions including the CX500M and the first two only had 408w on the 12v rail. The other two had 456w. If it's the earlier versions I would replace it. Infact even if it's the later versions I would be tempted to replace it. It's a low quality psu with cheap internals and wasn't really designed to power a high end system.
The Antec (review here) is a Seasonic built unit with 540w on the 12v rail and the Superflower has 546w on the 12v rail. Both are gold rated and both have a 5 year warranty.
The Superflower Leadex Gold 550w has bright white led's where you plug the cables in that cannot be turned off. Apart from that it's a excellent psu which has all of it's 550w on the 12v rail and a 5 year warranty. Review here.
The EVGA Supernova GS 550w (review here)and 650w (review here) are Seasonic built units both of which have 5 year warranties. The 550w has 540w on the 12v rail while the 650w has 648w on the 12v rail.
The EVGA Supernova G2 650w is a Superflower built unit and is basically a Leadex Gold with a different fan and no led's. It has a excellent 7 year warranty. Review here.
The Corsair RM650X has 648w on the 12v rail and has a 7 year warranty. Can't find a review on the 650w version but one on the 750w version is here.
Cracking value at the moment is the XFX TS750w at £72.95. It's a Seasonic built gold rated unit with a 5 year warranty and 744w on the 12v rail. The downside is that all the cables are hardwired. No reviews of the 750w version but there is one of the 650w version here.
