Hello folks, I am about to build my 3rd gaming pc. And the last component I cannot figure out is my psu. I was hoping for some suggestions. My budget is 80 pounds tops. (only money left) I don't want overkill. Just enough to do what is listed with some leeway.
Rig:
Cpu: AMD FX 8320 (Will be oc @4ghz) From what I have seen it can be set at 4ghz without adding more voltage.
Motherboard: Gigabyte 990FXA-UD3 AMD 990FX
Gfx: Gigabyte Gtx 660 windforce 2x 2gb (one gfx card not two incase of confusion)
Ram: Corsair vengeance 8gb (2x 4gb)
Storage: 60 gb corsair ssd + 1 tb hdd
Case is antec 300 one case. (Bent sides for more space) With 2 exhaust + 2 intake fans.
I think that should do.
Any help is appreciated, thank you for reading folks.
Rig:
