psu test
You said in laymans terms, thought I would keep it simple for you, guess it was to complex for you to do.
Yeah, stick it in a pc and turn it on?
Solid advice, that's what I'd do.
You can also short out 2 wires on the 24 pin connector which should kick the PSU in to life (ie turn the fans on)
What makes you think it is DOA?
tried in pc nothing so put other psu back in and pcs fine ( noisy but fine) , did the green and black short with a fan and nothing still so assuming its dead
