PSU to Hard Drive cable
29 Jun 2012
Sounds thick, but i am after one! i have a modular PSU and i cant for the life of me find any cables for it to go to my hard drive (i just bought a new hdd) what cable do i need i have the sata
My modular PSU came with a cable that was a 4 x HDD power cable, so it was one cable with 4 power connection on, is there something like that for you?
can u link me to one? that comes of the modular supply goes to two satas or at least the configuration for it
that will power the hdd as long as i get a female convertor
See now I'm confused, I thought that it would plug straight into the PSU and then straight into the HDD, they are a thin cable connection just a bit bigger than the SATA cable you would plug in next to it?
Picture may help.
Ok, so I found a picture of your PSU (with all cables) here:
fullimage.php
http://www.hardwaresecrets.com/fullimage.php?image=52105
The one you need is at the bottom right of that picture.
I would suggest contacting Silverstone directly.
