PSU up to scratch?
9 Nov 2006
Glasgow, South Side
Hi,
Just wondering if my 480w Tagan power supply would be fine with the newer GTX260/HD4870 cards?
Currently running a HD2900, stable, so I'm assuming this shouldn't be a problem.
Cheers.
Power wise I would say it's ok, but for the 4870 you need 2 x 6pin PCIe connectors so you'd need to check you've got those. If not you can get an adaptor go from a molex - 6pin.
