My current Spec is in my sig, and as you can see I'm running a Hiper (Oh dear...)
It sounds like the fan ball bearing has dislodged, but I've had this PC for over 1.5 years, and I'm slightly worried about the Hiper's track record so looking to replace it (not taking any chances with the rest of my PC).
As a student saving to go off travelling, my budget is relatively tight, but as I know the PSU is a vital component, I can probably spare £70-80.
I was looking to get a Corsair, but are the modular significantly more reliable, or do you pay solely for the ease of use, also are there any other brands I should be looking at?
P.S. a quiet PSU is neccessary, but not ultra silent etc.
Cheers!
Cheers!
Best of luck with the PC, hope it's ok after being 'Hipered'
