psu upgrade
12 Apr 2012
Hi I am upgrading my case and psu, I am getting phanteks pro case and was looking at the superflower leadex 750w gold was just wondering if anyone thinks there is a better quality psu for the money or have I made the right choice
my specs are
amd 8120 overclocked
sabertooth 990fx
xigmatek aiger 2x 120mm + 3x 120 mm case fans 2x 80mm
16gb ddr3 = 4 sticks
ssd + hdd
and a gtx 550ti (for now )
hoping to raid another ssd at some point and get the best i can afford on the gpu also going water cooled after crimbo
Crap just saw this, if you're sticking to a single card (gtx 770 or 280x) then this will be fine
http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-SF
Very reliable and has a 5year warranty. Even a 290x will run fine on this
Did look at that originally but didn't know if it would be enough with water cooling, high end gpu overclocked and some case lights just wanted to make sure I would have enough room to expand don't think I would be able to afford crossfire/sli no matter how much I wish lol was looking also at the 750w supernova g2 as a previous post suggested
