PSU Usage monitor tool
20 Aug 2008
Hi i have a Corsair 650W PSU
And a ASUS M3A32-MVP DELUXE Motherboard,
Is there a App or something I can download to see how much wattage i'm using. I know there is a PSU calculator site but I want to know how much exactly i'm using.
Cheers
just get power meter it will only cost you 9.99quid. just google it.If i remember correctly gigabyte odin psu comes with a program that you can monitor your psu consumtion.
Graphic card is biggest power waster so telling that would help lot.
Also CPU model and number of HDDs would help.
If you have noisy fans problem instead of ordinary cheap power meter yiu might want to consider this Zalman fan controller:
http://www.silentpcreview.com/article758-page1.html
Would love one of these too, as I'm unsure if my current PSU is enough..
Considering general shooting fly with SS-18 trend it's probably good for two or three.
http://web.aanet.com.au/SnooP/psucalc.php
QUOTE]
I have one of these, and build qulaity is pretty good, and its easy to use. Haven;t powered up yet though so can't comment on how nice it looks
That is excellent. I have one of these and as well as controlling 4 fans it has 4 temp probes and tells you the power draw of your pc. It's amazing to watch the power draw going up and down.
