I've just bought a new PSU. It's not quiet enough. The fan has 3 speeds, as far as I can determine by ear;
Slow speed - inaudible. No problems there, but it only seems to occur for the first ~30s after the PC is switched on.
Fast speed - ludicrously loud. Audible outside the room, round a corner, down a flight of stairs and round another corner. Happened once when I was running Prime to test overclocked stability on my new CPU and my motherboard BIOS was insisting that I didn't have a CPU fan plugged in (I do, but not in the power header the BIOS monitors). Hasn't happened since.
Medium speed is the issue. The main noise is tolerable. Not good, but tolerable. There's a second component to the noise, though, which is a more annoying sound. I think it's vibration transmitted to the case from the PSU. If I touch the top of the case, above the PSU, the sound changes in tone and reduces in volume and I can feel a slight vibration. I'm thinking that vibration in the chassis might account for the rest of the annoying component of noise.
So...damping. I've looked at this:
http://www.overclockers.co.uk/showproduct.php?prodid=CB-029-AK&groupid=701&catid=1428&subcat=1431
but that's for the rear of the PSU. The fan is on the bottom of the PSU. I'd like something to put on the chassis where the PSU rests on it. Thin, of course, so the PSU can still be screwed in. My cooler has thin rubbery strips stuck on it where the fan goes, for just that reason - that's the sort of thing I'm thinking of.
I've been offered an RMA because the PSU isn't as described (not the shop's fault - the manufacturer changed the specs) but right now I'm seeing the noise as a challenge
It's louder than the OCZ StealthXstream I bought it to replace. Well, some of the time. The OCZ's fan was worn and when it got rattling it was much louder. But I think this new PSU (Superflower Amazon) isn't louder per se. I think it's vibration in the case. I probably should just RMA it...but that's too easy.
How about door frame insulation? That's thin and compressible, but I think it would dampen vibrations quite well.
