- 24 May 2003
- UK
When you go to buy a power supply, the output voltage is usually shown for 3 voltages: +3.3v, +5v and +12v.
Most CPU's seem to use +1v or above so where is it derived from and why is it not mentioned in PSU specs ? (perhaps it is derived from the +3.3v rail and so isn't needed to be displayed as it's already covered) ?
Also generally speaking what sort of devices would these voltages power ?
I know that +12v is used for graphics cards but what about the +3.3v and +5v outputs ?
Finally why are negative voltages used on the 5v and 12v rails ?
Using the Hardware Monitor I get a weird reading from the -5v and -12v rails and am concerned about the PSU although it's been showing those kind of readings for ages
(below)
(below)
