Caporegime
- 1 Mar 2008
Guys, I bought a Winpower (don't ask) 750w PSU but it won't supply power to my rig.
Was about to RMA it, (which I'll have to do over the phone
)until I read this:
Maybe it's just on the wrong setting? How do I change it?
EDIT: There doesn't seem to be a switch that changes it. Where it should be, there is a sticker that says "AC 230V"
Features
Dual 80mm slience bearing fan
put Voltage: 95-132VAC or 190-264 VAC switchable
AC input Frequency:50HZ/60HZ
AC input Current:10A res max. for 115VAC, 5A res max. for 230VAC
Ripple-noise:5A res max. for 230VAC
Operation temperature:0oC ~+40oC
Hold up time :16ms
Dielectric withstand:Input to frame ground 1800VAC for 1 second
Power good signalower on delay time 100ms to 500ms
power failC>=1ms
Overload protection :150%
