- 13 Aug 2011
Now I understand that there's dozens of different PSU calculators out there, and I've tried using them all, but they're all telling me different things. The wattage I need spreads from about 575w to about 725w depending on the calculator I use. So I'd just like someone with first hand experience to suggest to me a comfortable wattage (and maybe a few PSU brands I can trust seeming as I've never built before).
My build is going to be:
CPU/Processor:
-Intel i5 2500k, stock 3.3GHz (3.7GHz turbo boost). I plan to overclock a fair amount in the future, but probably not right to the limits.
Motherboard:
Gigabyte GA-Z68X-UDH3-B3, Intel Z68, 1155, PCI-E 2.0 (x16), DDR3 1866/2133, SATA 6Gb/s, RAID, ATX
Graphics Card:
-EVGA NVidia GeForce GTX 570 HD (factory clocked to 797MHz)
Memory:
-8GB (2x4GB) Corsair DDR3 Vengeance Jet Black, PC3-14900 (1866), Non-ECC, CAS 9-10-9-27, XMP, 1.50V
Drives:
-Samsung SH-B123L/BSBP 12x Blu-ray BD-ROM & DVDRW Combo
-60GB OCZ Agility 3 SSD, 2.5" SATA 6Gb/s
-1TB Seagate ST31000524AS Barracuda 7200rpm, SATA 6Gb/s
Cooling:
-4 120mm case fans
-1 proper CPU air cooler when I begin to overclock (until then I'll just use stock)
Other Devices:
-About 4 USB devices plugged in at any 1 time
So, to reiterate, what wattage and brand of psu will be comfortable for this build?
~Also feel free to critique the rest of the build as so far I've bought the CPU, Mobo and GPU, but none else
CPU/Processor:
Motherboard:
Graphics Card:
Memory:
Drives:
Cooling:
-4 120mm case fans
Other Devices:
