hi there,
I'm looking to shorten some of the cables to my psu.. i was wondering if it would be ok to just cut out a length of cable and just connect (twist together) the bare wires and then use electrical tape over it?
Doing it this way would negate the need to buy expensive crimping tools and crimps.
Any tips or handy hints most appreciated!
thanks!
thanks!
