PSU with 1 six-pin connector, help!
13 May 2009
Norwich
Have just upgraded GPU (among other parts)
I have a 6870 with two 6 pin connecto slots. My PSU (model OCZ600msxp) has one 6 pins connector. With this GPU came a ATX connector with 6 pins on the other end, but the ATX connector has 3 pins. Can I plug in this ATX connector in my PSU and plug the 6 pin end in my GPU to fill both 6 pin slots? Can one of my six pin connectors power the GPU? Will this work with my PSU, or should I get a PSU with two seperate 6 pins connectors?
Re-read your opening post :)
Use the molex to 6 pin and the PCI-E connector coming from the PSU together.
So yeah, I found this outgoing 8 pin that isn't connected to anything, doesn't seem to fit either the GPU or molex to 6 pin...
I've looked everywhere for somewhere to put this molex, doesn't seem to be anywhere.
I see.
I have a 8 PIN to 6 pin (with 2 small pins seperate) that I was using with my 5750.
As well as this, I need the molex to 6 pin, right?
I can't find anywhere to put the 3 (with one empty) molex to 6 pin..
