I've got a problem.
Approx once a week for the past year, my computer does this. The mouse freezes, and after a couple of minutes the machine reboots. It happens when the computer isn't under load, e.g. surfing the web. The computer is self-built and 6 years old.
It's getting more frequent and I want to fix it.
I've tried
I'm running Windows 10 Professional 64-bit. Online forums have not been helpful, only shown that others have this problem.
Faulty GPU?
I've tried
- Uninstall the Nvidia drivers with Display Driver Uninstaller and reinstall
- Clean out computer, check heatsinks and make dust-free
- Monitor temperatures (all fine)
- Run sfc and dism. After this took 13 days to next crash
On Wed 13/05/2020 12:20:16 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\051320-25406-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1C2390)
Bugcheck code: 0x133 (0x1, 0x1E00, 0xFFFFF80030773358, 0x0)
Error: DPC_WATCHDOG_VIOLATION
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above. This could be caused by either a non-responding driver or non-responding hardware. This bug check can also occur because of overheated CPUs (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x128c34)
file path: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_d223212c0a2275b5\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 441.87
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 441.87
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 441.87 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation DPC_WATCHDOG_VIOLATION
On Fri 01/05/2020 16:20:25 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\050120-7453-01.dmp
This was probably caused by the following module: watchdog.sys (watchdog+0x41A0)
Bugcheck code: 0x119 (0x2, 0xFFFFFFFFC000000D, 0xFFFF878A0AF8E960, 0xFFFF888F561D8810)
Error: VIDEO_SCHEDULER_INTERNAL_ERROR
file path: C:\WINDOWS\system32\drivers\watchdog.sys
description: Watchdog Driver
Bug check description: This indicates that the video scheduler has detected a fatal violation.
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Fri 17/04/2020 00:48:04 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\041720-8578-01.dmp
Bugcheck code: 0x119 (0x2, 0xFFFFFFFFC000000D, 0xFFFFCD83F9379960, 0xFFFFCF86134EE9D0)
Faulty GPU?
Here's my thinking so far:
