- 17 Jun 2005
- Near Brighton
Hello
Ive got a 1998 Peugeot 106 zest 3 1.1 and wanted to fit a new headunit to it. Now ive bought this head unit. Unfortunatly it seems it wont fit without a lot of hassel. There is no simple plug to plug into the headunit, all the wires from the car seem to be seperate etc.
Now, would i be able to buy this, then connect all the seperate wires to that and plug my lead from headunit onto it?
Thanks, if you need pictures to understand just ask and i will go take some
Thanks
Thanks
