SgtTupac said:What are these like? They quick? Been looking at a few, what would expected power output be if i was to put a set of Twin 40's, wild cam and straight thru exhaust on it? Do the 1.9s handle? Any problems? Cheers
Dogbreath said:The 8v engine is already in a fairly high state of tune, so extracting significantly more power is not cheap. The Mi16 engine swap is popular and quite straightforward, though the injection system and exhaust need a bit of modding to fit the 205.
Good handling, though these cars pretty much defined the term "lift off oversteer"!
Shells are surprisingly rot free, though a few more rusty examples around these days. Check for cracking at the top of the door pillars!
SgtTupac said:So they go sideways pretty much easy then? Thats what i like to hear! Off to look at one on the weekend![]()
shez said:What insurance catagory is the 1.9 and 1.6 gti?
